asperber
Oct 15, 2020Follower
RBK752 - Phone constantly changing between nodes
I have an orbi pair and my Samsung phone keeps changing constantly between nodes. Is there any way to make it so it's less sensitive to changes between signal strength, and will therefore stay conne...
Oct 16, 2020Guru - Experienced User
Is this the only device that experiences this?
What model is this device and what OS is loaded on your device?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Change CTS to 2347. Save settings and reboot the router and satellite(s).
asperber wrote:I have an orbi pair and my Samsung phone keeps changing constantly between nodes. Is there any way to make it so it's less sensitive to changes between signal strength, and will therefore stay connected longer?
