Lauku
Jan 11, 2023Tutor
RBK752 : smartphone will try to reconnect endlessly when moving around the house
Hello to everyone, I have the following situation home : Router from ISP provider in the basement. From there, 3 ethernet cables. Two of the cables are connected to an Access point from my ISP (e...
Jan 11, 2023Guru - Experienced User
You're mixing technologies. The orbi mesh has smart roaming built in to function on its connected router/satellites. The other AP's won't integrate with the orbi like that. So if a device is connected to one of the other AP's its going to tend to be "stickier" in that it won't want to roam until the signal is almost unusable (as you're finding out).
Maybe at times you're connected to an AP that has just enough coverage when walking around versus others being further away. That can cause the symptoms you're seeing.
