Lauku
Jan 11, 2023Tutor
RBK752 : smartphone will try to reconnect endlessly when moving around the house
Hello to everyone, I have the following situation home : Router from ISP provider in the basement. From there, 3 ethernet cables. Two of the cables are connected to an Access point from my ISP (e...
Lauku
Jan 11, 2023Tutor
Thanks for your answer. It might be so, but I don't think it is the answer, as I have tries many times to walk from my ISP access point area to Orbi area and not always my phone won't reconnect. Sometimes, it actually swith like it should.
Jan 11, 2023Guru - Experienced User
Again, its because your mixing systems. Your phone is the one that actually does the roaming off its own protocol. But when its switching between 2 systems with different roaming protocols/settings, it isn't nearly as efficient as its picking up different signals. Sometimes it might work fine, others it can be horrendous and need the wifi on/off method to get it to switch.
You're welcome to not believe me.
