JimTurkey
Sep 26, 2021Guide
RBK752 & U-Verse. BGW210
So I think I hooked everything up correctly. But something isn't correct as I cannot watch U-Verse TV. The internet seems to work fine but U-Verse freezes about 10 seconds of viewing. Resetting the r...
- Sep 26, 2021
Disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
JimTurkey
Sep 26, 2021Guide
thanks so much for the links!
one question, though … with all of the features being disabled in AP Mode, what is/are the advantage of AP Mode?
Sep 26, 2021Guru - Experienced User
Avoid hassles of ISPs modems that may not work right with the RBR In router mode.
IF the RBR is crashing the ISP modem, possible some thing is going on at the modem level as well.
- JimTurkeySep 26, 2021Guidein my original post, i meant to add that the internet seems to work fine. it’s only when attempting to watch u-verse that i encounter a problem.
does that change your answer? is AP Mode still the recommendation?
