JimTurkey
Sep 26, 2021Guide
RBK752 & U-Verse. BGW210
So I think I hooked everything up correctly. But something isn't correct as I cannot watch U-Verse TV. The internet seems to work fine but U-Verse freezes about 10 seconds of viewing. Resetting the r...
- Sep 26, 2021
Disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
JimTurkey
Sep 26, 2021Guide
yeah, i can’t watch cable tv.
so when i do AP Mode, do i need to worry about IP Passthrough, turn off the at&t wi-fi, or anything on the AT&T site?
Sep 26, 2021Guru - Experienced User
Turn off IP passthru for AP mode.
- JimTurkeySep 26, 2021Guidebut no changes to the default firewall settings, right?
- FURRYe38Sep 26, 2021Guru - Experienced User
Use default firewall settings or recommended by the ISP.
- JimTurkeySep 26, 2021Guidegreat thanks.
last question (i think), i connect the orbi ethernet to isp router. that is the only one. all others (xbox, tv, etc) would be connected to the orbi, right? - FURRYe38Sep 26, 2021Guru - Experienced User
Can be connected to the modem aswell.
- JimTurkeySep 26, 2021Guideoh glad i asked! thanks for your help!
- FURRYe38Sep 27, 2021Guru - Experienced User
- JimTurkeySep 27, 2021Guide
So more or less, AP Mode allows me to take advantage of Netgear's same high speeds and wider wi-fi range as Router Mode but without the side benefits such as the Orbi app and Netgear Armour?
Only Armor would not be avaialble. You can still use Orbi app.
Great! My mine concern is the wi-fi speed and range anyway. The others are just added benefits (that would be nice, especially Armour).
:smileywink:
- FURRYe38Oct 03, 2021Guru - Experienced User
"Turn off IP passthru for AP mode." means OFF on the modem.
- JimTurkeyOct 03, 2021Guide
Thanks. We're up and running!
Please mark your thread as solved so others will know.
Enjoy.
