jcleck
Sep 17, 2021Follower
RBK752-100NAS 2.4 Device Connection Issue
I have the RBK752 and one satelitte. Both were set up out of the box following standard setup procedure and I have not since changed any settings since it was set up with. I am having issues getting ...
Sep 17, 2021Guru - Experienced User
What FW version are you using?
What channels are you using? 1, 6 or 11 is recommended.
Try disabling AX mode on 2.4Ghz on the RBR. Under Basic Tab/Wireless settings. Remove the check mark from the 2.4Ghz check box.
Set CTS value to 2347 under Advanced Tab/Advanced Settings/Wireless Settings.
