Maxr67's avatar
Maxr67
RBK752 and new satellite RBS350
Volevo espandere il mio sistema AX4200 - RBK752 con un nuovo satellite e volevo sapere se il modello RBS350 ( piu' economico) è compatibile con il mio sistema.
Grazie
  • I wanted to expand my AX4200 - RBK752 system with a new satellite and I wanted to know if the (cheaper) RBS350 model is compatible with my system.
    Thank you
    Grazie
    • FURRYe38's avatar
      The 3 series is a dual band system where the 7 and 8 series is a 3 band system. I don't believe dual band units will work on 7 series. I know that EX7500, 7700, 8000 and EAX80 extenders work.
