AggedwNG
Oct 04, 2022Apprentice
RBK752 (AX4200 bundle) poor ethernet speeds
Have a 940mbps download speed coming in to an Arris SB8200 modem from the ISP connected via cat6 to an RBK752, with an RBS connected via wireless backhaul. RBK752 internal speed test verifies the 940m...
Oct 05, 2022Guru - Experienced User
What firmware version are you on?
Are you using any parental controls, traffic monitoring, access control, or qos?
Try with those disabled.
Also, how are you testing speeds? (What app or is it the built in speedtest)
