AggedwNG
Oct 04, 2022Apprentice
RBK752 (AX4200 bundle) poor ethernet speeds
Have a 940mbps download speed coming in to an Arris SB8200 modem from the ISP connected via cat6 to an RBK752, with an RBS connected via wireless backhaul. RBK752 internal speed test verifies the 940m...
Oct 05, 2022Guru - Experienced User
What firmware version are you on?
Are you using any parental controls, traffic monitoring, access control, or qos?
Try with those disabled.
Also, how are you testing speeds? (What app or is it the built in speedtest)
AggedwNG
Oct 05, 2022Apprentice
Hello Plemans. Please see my responses below.
FW: 4.6.9.11
No parental controls or QOS, Armor but do have Access Control enabled. I did have a trial version active long ago for both Armor and PC but these have long since expired and deactivated. Tried testing this morning with Access Control turned off on the router, same speed results at the switch and router Lan ports.
I am testing speed with router's internal speed test and also using speedtest.net on external devices connected via the switch, router Lan ports and modem.
FW: 4.6.9.11
- plemansOct 06, 2022Guru - Experienced User
I'd try factory resetting the router.
during the reinstall, tests its speeds without changing any armor/SPC/access control/etc.
- AggedwNGOct 06, 2022ApprenticeThanks for the reply. I did this on both the router and satellite after the fw update and also did this again last night. I don't reuse any configuration settings since I have a small list of devices ( < 10) and just manually reconfigure. Still no change in speed at the switch or the Lan ports on the back of the router.
- Mikey94025Oct 06, 2022Hero
AggedwNG wrote:
FW: 4.6.9.11
I am testing speed with router's internal speed test and also using speedtest.net on external devices connected via the switch, router Lan ports and modem.Do you also have Orbi's Traffic Meter disabled? http://orbilogin.com, Advanced Tab, Advanced / Traffic Meter. That's the other option mentioned in the community FAQ: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944
- AggedwNGOct 06, 2022ApprenticeHello Mikey94025. Thanks for your reply.
Traffic Meter is disabled as well. I have no advanced features enabled, except for access control. I ran a few more tests again, just to eliminate all possible variables I could think of (even using varying Cat6 cables I could find in my closet) resulting in the following:
Removed the switch, powered off all devices that are allowed to connect to the router wirelessly (to avoid any interfering bandwidth consumption) and even removed the satellite and tested with the router only connected to my modem and access control on. Similar result speeds at the Lan ports (1-3) on the router, with 1 wired test device (laptop) with a varied download range of 312-422mbps from the ports. Speed at the modem without router in the chain, 946mbps.
Tested again with the router back in the chain, satellite powered off and access control off, varied download range of 318-411mbps from the ports (1-3). Speed at the modem, without router in the chain, 952mbps.- FURRYe38Oct 09, 2022Guru - Experienced User
Possible you may have a faulty RBR that needs replaced.
Any chance you have a friend, family or neighbor you can take the RBR to to see if the problem follows or not?
