AggedwNG
Oct 04, 2022Apprentice
RBK752 (AX4200 bundle) poor ethernet speeds
Have a 940mbps download speed coming in to an Arris SB8200 modem from the ISP connected via cat6 to an RBK752, with an RBS connected via wireless backhaul. RBK752 internal speed test verifies the 940m...
Oct 06, 2022Guru - Experienced User
I'd try factory resetting the router.
during the reinstall, tests its speeds without changing any armor/SPC/access control/etc.
AggedwNG
Oct 06, 2022Apprentice
Thanks for the reply. I did this on both the router and satellite after the fw update and also did this again last night. I don't reuse any configuration settings since I have a small list of devices ( < 10) and just manually reconfigure. Still no change in speed at the switch or the Lan ports on the back of the router.
