musiclover360
Feb 01, 2021Aspirant
RBK752 AX4200. FIOS not connecting
AX4200 WiFi Mesh System (RBK752) and FIOS Brand new installation of Verizon and Orbi using Verizon Internet only. No Verzion router. Plan is to use the Orbi as the router. Only Orbi won't connect say...
Mstrbig
Feb 03, 2021Master
Brand new installation of Verizon and Orbi using Verizon Internet only. No Verzion router. Plan is to use the Orbi as the router. Only Orbi won't connect says there is no internet connection. Can't find Wifi using the Orbi app during Orbi setup. Anyone else have this problem. Everything I've found says turnoff Fios Router (there isn't one) or turnoff Verizon Wifi using Verizon App. Only it shows no network.
If you have FIOS you should have an Optical Network Terminal (ONT). Your RBR750 Orbi needs to be connected from its WAN port to ONT and configured for router mode. As FURRYe38 stated, you need to turn off the ONT, wait 30 seconds to 1 minute and turn it back on. This will clear the ONT, allow it to get ISP info and distribute an IP address to your Orbi router. Your Orbi router will now be the DHCP server for the network and assign IP addresses to your device.
