Readthebook
Dec 01, 2020Aspirant
RBK752 AX4200 Slow download speeds
Just got the Orbi Wifi6 2 beacon WiFi setup a few days ago. What I’ve noticed since then is that when downloading updates on my raspberry pi via apt upgrade, or when VPN’d to work and downloading...
Readthebook
An update:
I just swapped back to my old R7000 Nighthawk.
Zero download problems. Pulling 18-20 MB/sec down, sustained.
Looks like these Orbis are garbage and are going back unless someone has a suggestion.
- FURRYe38Dec 01, 2020Guru - Experienced User
IWhat is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry disabling the following and see:
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849Get good speed from my 8 series with my mac book pro:
