reproman81
Dec 06, 2021Aspirant
RBK752 Blocked Websites
For a little while now I have problems connecting to some websites on all my devices and in chrome get an error ‘err_http2_protocol_error’ and I have tried other browsers. I wondered if it was an is...
- Dec 06, 2021
Hi FURRYe38
I have been able to borrow another router and get the same result so it seems as you said its an ISP issue not the router. Thank you for your help.
Kind regards
Paul
Dec 06, 2021Guru - Experienced User
Looking to see if there is a built in router at the ISP modem level. Possible there maybe.
IF this has been working and just started recently, possible this could be a ISP issue.
Is Armor enabled on the RBR? Disable it if it is.
Try this, power OFF the RBR and connect 1 wired PC to the ISP modem. Test same web sites with the one PC conencted to the modem...
reproman81
Hi FURRYe38
Kind regards
Paul
- FURRYe38Dec 06, 2021Guru - Experienced User
Good Luck.
