egan06
Jan 21, 2021Tutor
RBK752 compatibility
Hello, I would really like to know that if I bought the new mesh752 kit if I can use my old satellites that came with my RBK40 ((RBS40)) that way I could set up the routers (twin pack) in the both flo...
Jan 21, 2021Guru - Experienced User
You can only Ethernet connect the RBS40 to Orbi AX systems.
egan06 wrote:
Hello, I would really like to know that if I bought the new mesh752 kit if I can use my old satellites that came with my RBK40 ((RBS40)) that way I could set up the routers (twin pack) in the both floors and have satellites further away too?
Anybody who can give a definite answer would be greatly appreciated as these are very expensive. Hope you can help? Thanks
