egan06's avatar
egan06
Tutor
Jan 21, 2021
RBK752 compatible
Hello, I would really like to know that if I bought the new mesh752 kit if I can use my old satellites that came with my RBK40 ((RBS40)) that way I could set up the routers (twin pack) in the both floors and have satellites further away too?
Anybody who can give a definite answer would be greatly appreciated as these are very expensive. Hope you can help? Thanks
  • FURRYe38's avatar
    They can be used via ethernet connection only. RBS AC series are not wirelessly compatible.
    • egan06's avatar
      egan06
      Tutor
      Thanks.. they are plug in wireless satellites though ??
