Retired_Member
Oct 16, 2021RBK752 ethernet ports are slow
I have my RBK752 connected directly to my ONT via ethernet. 1GB FIOS service. I have a netgear switch connected to one of the Orbi's ethernet ports. On the Orbi App, I am hitting close to those n...
Oct 16, 2021Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
What is the connection rate seen on the RBRs Advanced tab/Show Statistics button.
There you should see LAN ports listed. 1000Mpbs should be seen next to each LAN entry.
Whats the WAN port speed seen here as well? Should be 1000Mpbs too.
- Retired_MemberOct 17, 2021
Thanks...
Netgear GS108 ProSafe Gigabit Switch
I'm assuming you meant the Orbi router - V4.6.5.14_2.0.54
What is the Mfr and model # of the Internet Service Providers modem/ONT the NG router is connected too?
GPON ONT Model FOG421
Not sure where you find this, I've pasted the statistics page below.
1000M/Full on LAN1. LAN2 & 3 show 'Link Down'
1000M/Full
