max5962
Aug 12, 2021Aspirant
rbk752 need to be reboot daily
Hello Every one, i have an rbk 752 and i need to reboot it daily in order to works well I already disable metrics (suggested in forum), rollback DNS server to the default value ( i have adguard ...
Aug 12, 2021Guru - Experienced User
Does the front LED appear to show anything when you loose internet?
What devices do you have connected?
Both wire and wireless loose connections?
max5962
Aug 20, 2021Aspirant
Hello,
it's an rbk752 orbi.
| Router | RBR750 | RBR750 | V4.6.3.7 | Veuillez patienter quelques instants... |
| Satellite | RBS750 | Orbi Satellite-1 | V4.6.3.7 | Veuillez patienter quelques instants... |
Does the front LED appear to show anything when you loose internet? : sometimes pink led is on but not immediately.
What devices do you have connected? : many wifi ( IOT devices , computer, smartphone), some wired ( NAS, computer )
Both wire and wireless loose connections? yes
I swtich router mode to AP mode, any no issue since 4 days.
I think DHCP implementation is really buggy !
- FURRYe38Aug 20, 2021Guru - Experienced User
