max5962
Aug 12, 2021Aspirant
rbk752 need to be reboot daily
Hello Every one, i have an rbk 752 and i need to reboot it daily in order to works well I already disable metrics (suggested in forum), rollback DNS server to the default value ( i have adguard ...
max5962
Aug 20, 2021Aspirant
Hello,
it's an rbk752 orbi.
| Router | RBR750 | RBR750 | V4.6.3.7 | Veuillez patienter quelques instants... |
| Satellite | RBS750 | Orbi Satellite-1 | V4.6.3.7 | Veuillez patienter quelques instants... |
Does the front LED appear to show anything when you loose internet? : sometimes pink led is on but not immediately.
What devices do you have connected? : many wifi ( IOT devices , computer, smartphone), some wired ( NAS, computer )
Both wire and wireless loose connections? yes
I swtich router mode to AP mode, any no issue since 4 days.
I think DHCP implementation is really buggy !
Aug 20, 2021Guru - Experienced User
