bobpak
Sep 22, 2020Aspirant
RBK752 Orbi Router & Satellite Install
Can the subject Orbi pair be installed via a wired connection between the gigabit ethernet ports on each or only via wifi connectivity between each of them?
CrimpOn
Sep 22, 2020Guru - Experienced User
bobpak wrote:Can the subject Orbi pair be installed via a wired connection between the gigabit ethernet ports on each or only via wifi connectivity between each of them?
It appears that the answer is "Yes", provided that certain gigabit switches are not between the router and satellite.
You might want to look at the community forum for the AX product line and search for "ethernet backhaul".
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
