bobpak
Sep 22, 2020Aspirant
RBK752 Orbi Router & Satellite Install
Can the subject Orbi pair be installed via a wired connection between the gigabit ethernet ports on each or only via wifi connectivity between each of them?
Mstrbig
Sep 22, 2020Master
bobpak wrote:Can the subject Orbi pair be installed via a wired connection between the gigabit ethernet ports on each or only via wifi connectivity between each of them?
I have the RBK753 system and both satellites are wired through a NETGEAR 16-Port Gigabit Ethernet Unmanaged Switch (GS316). You can also wire them direct, router to satellites.
