cheechy
Jan 21, 2021Follower
RBK752 placement and outdoor Ring cameras
Hi there looking for some guidance on placement as I'm new to Mesh. Decided to take the plunge on the RBK752 wifi6 pack and setup based on known issues getting to outside Ring cameras. Now its setup ...
Jan 21, 2021Guru - Experienced User
Stone/concrete are 2 of the worst materials for wifi as it blocks very well.
Which Building Materials Can Block Wi-Fi Signals? (eyenetworks.no)
And the AX spec didn't up the broadcast power because that's set by the FCC so you don't see a whole lot of additional penetration from AX routers. Its a little more effecient at lower power which is why it "has more range". But even if the AX device does penetrate better for the camera's, the camera's antenna/broadcast isn't any better so its return signal is still going to be weak.
