hexum
Nov 04, 2022Tutor
RBK752 RBR750 Crashes During High Speed Downloads Over Ethernet
I got my RBK752 system March 2022 and I've had this problem since day one. What's happening is the router (RBR750) will crash 90% of the time I'm downloading large files at speeds higher than 800mbps...
CrimpOn
Nov 11, 2022Guru - Experienced User
hexum wrote:
I've had to set bandwidth limitations to 700mbps to be safe and prevent the crashing.
Curious how this is done?
hexum
Nov 12, 2022Tutor
I limited the bandwidth in each app I'm using for the download. I believe there are ways to do it in Windows Settings as well.
