Wonderboyexp
Dec 01, 2020Initiate
RBK752, RBS750, RBR750
Hi folks, Product Details Orbi WiFi Mesh WiFi 6 AX4200 RBK752 RBR750 Router RBS750 Satellite The tech support person said the firmware of the devices was up to date I use the Realtek 8812A...
- Dec 13, 2020It’s working now, seems like I had to move the Orbi satellite close to my computer. I though it had crazy range. But I moved it from 25 feet to 10 ft, it’s better now
Dec 01, 2020Guru - Experienced User
Realtek isn't the best at updating their drivers.
Are you using the realtek on a windows pc? if so, you should be able to log into the device manager and set it to prefer 2.4ghz.
or you could try disabling AX on the router and see if it helps.
