Wonderboyexp
Dec 01, 2020Initiate
RBK752, RBS750, RBR750
Hi folks, Product Details Orbi WiFi Mesh WiFi 6 AX4200 RBK752 RBR750 Router RBS750 Satellite The tech support person said the firmware of the devices was up to date I use the Realtek 8812A...
- Dec 13, 2020It’s working now, seems like I had to move the Orbi satellite close to my computer. I though it had crazy range. But I moved it from 25 feet to 10 ft, it’s better now
schumaku
Dec 03, 2020Guru - Experienced User
Wonderboyexp wrote:
I use the Realtek 8812AU dongle to connect to WiFi, all the drivers are up to date, it supports 5ghz.
Whatever you want to tell us here.... Operating system? Driver version? Disabled Bluetooth on the adapter?
Wonderboyexp wrote:
I was connected to my Spectrum router, I used to get about 15 mbps speed on the 5ghz channel and everything was going great.
That's about a number one would expect from a poor 2.4 GHz connection - nowhere of normal or great for a 5 GHz connection.
Wonderboyexp wrote:
Come Black Friday, my Roomate gets this Orbi WiFi 6 mesh and installs it. Now my phone connects to this network and I get 296 mbps speed on my phone.
Nice, isn't it? And you don't have to care if walking away or returining to the site - the phone will establish the connection to the longer reach 2.4 GHz link first, and then seamlessly roam to the 5 ghz link. Welcome to the year 2020!
Wonderboyexp wrote:
I reported this to customer care, they logged in to the Orbi app, changed wireless connection from 48 to 44. Or to only show 5ghz signal.
Interoperability issues are extremely hard to handle by support. They will go on the book ...
Wonderboyexp wrote:
However my Realtek dongle connects to this and I get a speed of 78 mbps for sometime. After some minutes the connection to my Realtek dongle keeps fluctuating, I can notice the signal strength move from 4 to 5 and 5 to 4 and the internet speed drops to 0.05 mbps.
Can just guess - it might have changed the band or the Orbi router/satellite.
Wonderboyexp wrote:
Anyone know why this is happening, before we got Orbi, I had an option to select 5ghz or 2.4 ghz channel and everything was fine, now I don’t get this option and the connection to my Realtek dongle keeps fluctuating once I m connected to the WiFi and the speeds vary
Things I would try is disabling the 20/40 MHz compatibility option on the client side, disable the on-board Bluetoth to get rid of some interference.
No you have not had an option - the old router announced to different networks for connecting to the one single network - and you had to change manually as the client would have stick to the band.
- WonderboyexpDec 13, 2020InitiateIt’s working now, seems like I had to move the Orbi satellite close to my computer. I though it had crazy range. But I moved it from 25 feet to 10 ft, it’s better now
