csukraw
Aug 21, 2020Tutor
RBK752 Real World WIFI Speeds
Won't let me put in the crrect model number for some reason. I have the RBK752 system (AX4200). I have a Gigabit connection and am able to get speeds over 900Mbps to my router consistently. When I am...
csukraw
Aug 24, 2020Tutor
Ok I checked and my IP addresses match. So my iPhone 11 Pro is still getting very slow speeds compared to hardwired. Here are a few comparing tests I just completed. Comparing wired to wireless connection speed tests over the app one right after another alternating. Som what is the reason I'm losing over 60% of my speed in some cases? Just wondering if there is somethiung wrong with the units I received and if they need to be returned.
WIFI
335 Mbps
385 Mbps
344 Mbps
407 Mbps
Hardwired
926 Mbps
918 Mbps
857 Mbps
903 Mbps
Mikey94025
Aug 24, 2020Hero
It may very likely just be wireless randomness but if you're concerned you can try swapping units. You need to make sure that your iPhone 11 Pro is communicating over wifi6 to the nearest thing. Maybe try turning off your satellites and running the speedtest app on your phone standing near the base station.
Have you changed any of the default settings and don't enable Circle or any of the other security features? Besides a fixed wifi channel (pick one that is not the most congested in your area, for 2.4Ghz only choose from 1/6/11) and WPA2 you shouldn't need to change anything else. You might improve wifi speeds with Short preamble.
Wireless has extra overhead than wired like encryption and packeting, but you should still be able to get 600-700 Mbps under the best conditions with your wifi 6 device.
