sal_p60
Nov 21, 2023Aspirant
RBK752 Satellite connect to only to backhaul 2,4 ghz
My Satellite only connct to backhaul 2,4 Ghz. I try different positions, factory reset, different channels... The connection is good (blue light) but only 2,4 Ghz
- Nov 22, 2023Ok Problem solved.
I go back to my old rb350 and i send back the 750.
Thanks all.
sal_p60
The device are connected where my ol rbk350 worked for years at 5 Ghz.
If i put the device in the sane room after a while it connect to 5ghz.
I can't believe that the rbk350 is powerful than the new.
CrimpOn
Nov 21, 2023Guru - Experienced User
Thanks for testing. This verifies that the satellite will connect to the router at 5G. (Amazing how long computer devices take sometimes. From power on to blue light seems to take foreeeeeeever!)
The 350 product uses the same 5G frequency for both user facing and router-satellite communication (channel
157 in North America, 108 in the rest of the world
The 750 uses different channels for user facing and router-satellite connection:
Thus, there should be no frequency difference between connecting 350's and 750's.
I don't suppose the 350 system is available to (temporarily) swap back in to verify that it still works as it did before?
- sal_p60Nov 21, 2023Aspirant
Now it connecto to 5Ghz with poor signal (I had to wait 30 minutes) ,
I swapped bajk to 350. on the same position and i have 5ghz with a good signal.- CrimpOnNov 21, 2023Guru - Experienced User
Thank you for taking the time to swap the 350 back in for this test. I am totally unable to come up with an explanation for how this could possibly happen.
Have searched for the fcc submission on the 350 to see how the internal antennas are oriented (and not found it).
Just makes no sense.
- FURRYe38Nov 22, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
I swapped bajk to 350. on the same position and i have 5ghz with a good signal.- sal_p60Nov 22, 2023AspirantOk Problem solved.
Thanks all.
