sal_p60
Nov 21, 2023Aspirant
RBK752 Satellite connect to only to backhaul 2,4 ghz
My Satellite only connct to backhaul 2,4 Ghz. I try different positions, factory reset, different channels... The connection is good (blue light) but only 2,4 Ghz
- Nov 22, 2023Ok Problem solved.
I go back to my old rb350 and i send back the 750.
Thanks all.
Nov 22, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
sal_p60 wrote:
Now it connecto to 5Ghz with poor signal (I had to wait 30 minutes) ,
I swapped bajk to 350. on the same position and i have 5ghz with a good signal.
