mtbor
Sep 19, 2023Guide
RBK752 Satellite in access point mode.
I recently put my orbi system behind my pfsense router for better QoS and bufferbloat mitigation. The orbi system hates not being in charge and seems to lack flexibility in it's configuration. In orde...
mtbor
Sep 19, 2023Guide
I'm using wireless backhaul.
CrimpOn
Sep 19, 2023Guru - Experienced User
Thanks. We see all sorts of posts where users have connected both router and satellites to the same switch.
Since satellites are easy to move around, can you try:
- Deleting the satellite from the Attached Devices display.
(If it is truly not connected, then an option should appear to Delete it. - Temporarily relocate the satellite to the same room as the router.
- On the Orbi web interface, main menu, select Add Orbi Satellite and follow the directions.
- If the satellite connects, then try moving it to the desired location.
Although not strictly required, many users prefer to reserve a specific IP address for the router and satellites in the primary router DHCP tables.
https://forums.serverbuilds.net/t/guide-static-ip-addresses-in-pfsense-static-dhcp/5779
- mtborSep 20, 2023GuideI will give this a try when I get home. The satellite is currently sitting 5 feet from the router and was connected before putting it into access point mode. I've reset the orbi twice and got the satellite connected, only to have it drop out when put into access point mode.
I will try again.- FURRYe38Sep 20, 2023Guru - Experienced User
Wondering if something on your host router is blocking RBS traffic.
How are you configuring the RBR for AP mode? Dynamic or Static? I recommend a static IP address configuration on the RBR that's out side of the host routers default IP address pool range. So when i have my 750 series online, the RBR is set for 192.168.1.75. My one RBS750, wired or wireless gets connected with a Dynamic IP address from the host router that's being used at the time.
While is same room with the RBR and RBS, 10-15 feet would be recommended distance between them.
- mtborSep 20, 2023GuideThis is probably my fault. Most advanced routing devices don't specifically require the use of the internet port on the router, it seems ORBI does. I set both the router and satellite as static in the pfsense DHCP table. I didn't seem to get a change, so I then plugged the cable into the internet port and hit sync on both devices...
The Orbi router lit up magenta thinking it has no internet connection, yet the internet is fine. The satellite lit up blue indicating a good link.
The router is no longer accessible via web interface or through the Orbi app.
I remain disappointed overall in the lack of flexibility, but I am happy the system is functioning.
Hopefully this set up doesn't negatively impact devices on the network from communicating with one another.
