BarryN
Aug 22, 2021Aspirant
RBK752 Satellite LED behavior
The LED light on my satellite turns on at random times. I thought this was just an initial synching thing. Anyone know if this is normal or what it means?
titaniumrx8
Aug 22, 2021Apprentice
What color(s)?
What is the color sequence and flashing pattern?
Can also be a reboot after a momentary power glitch. These satellites are very power sensitive. Mine haven't rebooted randomly since connecting them to UPSs.
BarryN
Thanks for your reply.
The LED shines blue for a few minutes and then turns off
- plemansAug 22, 2021Guru - Experienced User
It could be the backhaul connection from the satellite/router going from fair/good/unable to connect.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
