nathan_84
Aug 09, 2021Aspirant
RBK752 satellite restarts quite often in a day
I am using Mesh AX4200 WiFi 6 (Up to 4.2Gbps) (RBK752-100EUS) with one router + one satellite. Recently from 2 days back, my satellite restarts automatically (white light blinks and blue light come...
- Aug 09, 2021
nathan_84
Firmware: v4.6.3.7
The internet provider provides a RJ45 cable input which is connected directly to the router.
Size of home: 2 floors - each floor is 800 sqft- router is place in ground floor and satellite in first floor
There are two neighbours
It was working perfectly for 3 months since I bought, but thus restart occurs from this weekend.
I did tried rebooting router twice yesterday and today, but didn't helped.
Aug 09, 2021Guru - Experienced User
800sq ft maybe to small for both RBR and RBS.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What Wifi channels are you using on the RBR?
- nathan_84Aug 09, 2021AspirantI mean
Ground floor - 800 sqft
First floor - 800 sqft
If I don't have satellite, the signal from ground floor router can't reach my first floor bedroom.
I am using both 2.4 and 5. In fact it is auto.
I recently changed the security setting in wifi settings from default: wpa2-personal to wpa/wpa-2 personal and disabled netgear Armour (in security).
I changed above to connect Sonos soundbar for demo.
Then I reverted back to original defaults again ( wpa2- personal and enabled netgear armor)
Will this be due to that?
Should I need to reset to factory settings and reconfigure it?- FURRYe38Aug 09, 2021Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try with WPA2 only and with Armor disabled.
Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Can you connect SONO to the system via ethernet by chance?
At some point you migth reset the RBS and RBR and setup from scratch. Don't enable Armor and test...
- nathan_84Aug 09, 2021AspirantAll these setting by getting into router via browser right?
Sonos is no more at my home. It was there for few hours just to have demo.only during that time I changed the settings but reverted post that. Sonos do not have ethernet port.
