joespizza
Aug 03, 2020Follower
RBK752 Separate 2.4GHz and 5GHz SSIDs
Just got the RBK752 and was under the assumption I could separate 2.4GHz and 5GHz into 2 SSIDs as the RBK50 can. Those instructions via Telnet do not work and Netgear support indicate separating the...
Aug 03, 2020Guru - Experienced User
Telnet or separation of SSIDs is not officially supported on Orbi systems.
