Dantheman76
Oct 25, 2020Tutor
Rbk752 smart parental control
I read that compared to the cheaper rbk50 smart parental control is not on board of the rbk752? True? Will it come?
Oct 25, 2020Guru - Experienced User
Circle has not arrived on Orbi AX yet. NG has posted that it was in th road map. No further information on when that will happen.
- Dantheman76Oct 25, 2020TutorSo its basically wrong in the circle description.where clearly the ax devices are shown as supported. It will definitely come?
- FURRYe38Oct 25, 2020Guru - Experienced User
Well this KB doesn't list the Orbi AX as Circle supporting:
https://kb.netgear.com/000044718/Which-NETGEAR-routers-support-Circle-Smart-Parental-Controls
