Dantheman76
Oct 25, 2020Tutor
Rbk752 smart parental control
I read that compared to the cheaper rbk50 smart parental control is not on board of the rbk752? True? Will it come?
Dantheman76
Oct 25, 2020Tutor
So its basically wrong in the circle description.where clearly the ax devices are shown as supported. It will definitely come?
Oct 25, 2020Guru - Experienced User
Well this KB doesn't list the Orbi AX as Circle supporting:
https://kb.netgear.com/000044718/Which-NETGEAR-routers-support-Circle-Smart-Parental-Controls
