bmbrewe1
Mar 08, 2021Follower
RBK752 Speed Issues
I recently upgraded to the RBK752 AX4.2Gbps modem/router combo w/satellite. My home is 3,600sf and figured this would cover the home. I have gig speed through Xfinity. I am getting between 325-400 downstream & 30-40 upstream. The master bedroom is roughly 50ft from main router and the stream is slow w/some buffering. I spoke w/support and he made some technical adjustments in wireless settings but hasn't seemed to improve the speed. The speed test within the app is also not working. Has anyone experienced something similar or made any adjustments you might recommend?
1 Reply
Do wired devices test speeds faster?
What wireless devices are you using. Some may cap out at 400-500Mps:
https://community.netgear.com/t5/Orbi-AX/Am-I-Connected-to-WiFi-6/m-p/2067889#M13012
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
