Sparry33
Jun 24, 2020Tutor
Rbk752 support orbi voice rbs40v
I recently purchased a RBK752 and found a deal on the Orbi voice Rbs40v so I thought I would give it a try. Today I was told that the new Wi-Fi 6 routers do not work with Orbi voice. Does anyone know...
Sparry33
Jul 02, 2020Tutor
Thanks I connected it via Ethernet cable and it’s working but any devices connected to the Orbi voice show up as wired the light on the top is always red. Also you are not able to update the firmware unless you do a manual upgrade. I’m still on the fence as I was looking for a wireless system.
In today’s products they always support backward compatibility of older WiFi standards and this should not be any different.
Jul 02, 2020Guru - Experienced User
Well with the radios supporting different AX modes and such, there maybe some incompatbilities. There is some differences between AX and AC Orbi. IF a RBS is wired, then any wireless device connected to the RBS will appear as a wired device since the main backhaul is wired, not wirelss, so the status for any device on that line will appear as wired.
AX is still new and may have some incompatbilities. You may want to either return the RBS40v or return the Orbi AX system for a Orbi AC system which is more compatible with RBS AC.
