SpecificMouse
Oct 08, 2020Aspirant
RBK752 Trying to create time limits for specific devices connected to the wifi
Hello, Like a lot of people now-a-days my children are doing online classes here at home. I have a willful teenager who is using this oppertunity to access the internet after bedtime using his C...
- Oct 08, 2020
Does this help any?
Oct 08, 2020Guru - Experienced User
Does this help any?
SpecificMouse
Maybe I am just dense, but I can't seem to figure out how to make that happen. I have access control enabled, I check the devices I want to control (just my phone for now since I don't want to block them from school) but no option for schedule shows up. If I select the phone and just go to the schedule menu, then pick all day every day blocking, it doesn't affect the phone, nor does it seem to affect any other device on the network.
- FURRYe38Oct 08, 2020Guru - Experienced User
After applying the change, try a reboot of the phone and RBR to see if this changes the effect.
Possible you may need to set up a IP address reservation for the device as well. Under Advanced Tab/Settings/LAN Setup.
