Budshark
Oct 14, 2020Aspirant
RBK752 XBOX Double NAT when connected to satellite
Recently installed RBK752 with 2 XBOXs in house. One is connected (ethernet) to the RBR, second is connected (ethernet) to one of the satellites. The Xbox connected to the satellite gets the dreade...
Mstrbig
Oct 14, 2020Master
Budshark wrote:Recently installed RBK752 with 2 XBOXs in house. One is connected (ethernet) to the RBR, second is connected (ethernet) to one of the satellites. The Xbox connected to the satellite gets the dreaded double NAT error (always when connected via ethernet, occassionally when connected via wireless). Its 100% a problem with the satellite, as the other Xbox connected to the router does not have this issue, nor does the second if I turn off the nearby satellite.
I've seen several posts on this, but no resolution. Is Netgear working on this? Is there a documented fix?
Full setup: Arris TM1602A (Not NAT capable) -> RBR V3.2.16.6 -(wireless)-> RBSatellite -(ethernet)-> Xbox
If you change the RBR750 router to Access Point mode, it will solve the Xbox issue of the Double NAT.
