Budshark
Oct 14, 2020Aspirant
RBK752 XBOX Double NAT when connected to satellite
Recently installed RBK752 with 2 XBOXs in house. One is connected (ethernet) to the RBR, second is connected (ethernet) to one of the satellites. The Xbox connected to the satellite gets the dreade...
Oct 14, 2020Guru - Experienced User
Does manually changing ports on the Xbox Networking dashboard under Advanced Settings change the status any?
Has a power off for 1 minute then back on been performed since last update?
Budshark
I’ll test manually changing the ports but don’t think it will work as the other Xbox connected to the RBR is fine and when this one connects to the RBR it’s fine as well.
System has definitely been hard reset with extended power out since last update.
Chris
Chris
- MstrbigOct 14, 2020Master
ChrisI was mistaken before thinking you had an ISP modem/router which you don't. So this is a very unusual situation since you DO NOT have a double NAT configuration. The only explanation would be a smart router or device setup for DHCP distribution, or there is an issue with the Xbox. Try swapping the Xbox consoles and see if the issue follows the Xbox.
- FURRYe38Oct 14, 2020Guru - Experienced User
OH, well since you have two xbox consoles, hold the power button in the front of the consoles until they turn OFF.
Go into the RBRs web page and under Advanced Tab, WAN setup, change NAT filter to OPEN. Save the setting, then do a full reboot of the RBR. After the RBR is online and ready, power ON 1 of the consoles, try the one connected to the RBS 1st. Then power ON the other console.
Chris
