chet99
Aug 23, 2021Tutor
RBK753 - long connection time from startup - windows
Hey folks: It's been a bit of a bear setting up this system. After finally updating firmware manually, and fighting to connect satellites, it is now taking 5-10 minutes for windows machines to a...
- Aug 23, 2021
Glad that helped.
Please mark your thread as solved so others will know.
Enjoy.
chet99
Aug 23, 2021Tutor
Gah. I dug in tonight and bridged the Actiontec rather than just running off the WAN port. It seems to be working better - 3 of 5 windows devices are grabbing IPs wirelessly very quickly. (I just need to test the others). I'm not exactly sure why only the wireless windows devices were impacted - I'm thinking that both use the same 192.168.1.x gateway, and windows must somehow blast the WAN port for a response. (Not a network guru clearly).
If needed for other verizon users in my shoes who have a set top box - this link helped. (It is for a Quantum Gateway - but the info is there if you pick through the menues). I didn't forward any ports, but my DVR seems to be working.
Replace Fios Router with Your Router
I'm not going to mess with the firmware, as everything seems to be running. I think I was trying to use the file for satellites, not the router firmware. The filename is only a letter off - and must have picked the wrong file.
Thanks for the help - I have another question - but it is probably better for another thread.
Aug 23, 2021Guru - Experienced User
Glad that helped.
Enjoy.
