51Alan
Mar 02, 2021Guide
RBK753 - won't find updated firmware
My RBK753 system is running firmware 3.2.16.22. According to the Netgear website the latest firmware version is 3.2.17.12, and it was released in late January. However, when I check for firmware up...
- Mar 02, 2021
It's expected that most Orbi systems will not automatically detect the new firmware release soon aftert it's announced and posted for manual download. For most customers it's okay and they don't need to update right away. Making these new releases available on the support website supports anyone who does need the latest fixes or who wants to upgrade as soon as possible.
It is normal for companies to gradually update their installed customers with new firmware or software versions. Mobile app vendors do the same each time they make a new app version available in the app store.
This gradual rollout policy is to reduce risk, e.g., if there is some unexpected issue with the new firmware they want to minimize the set of customers negatively impacted by the bug. By gradually rolling out new firmware releases and monitoring customer-reported issues, they can halt the rollout as soon as a small number of customers begin reporting issues. They can also accelerate the rollout as more customers use the new firmware but do not report problems. The gradual rollout period might be over several weeks or multiple months.
GBAL
Mar 15, 2021Aspirant
HOW DO I PERFORM ANY UPDATES TO MY RBK753 SYSTEM
Mar 15, 2021Guru - Experienced User
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Update the RBS first then RBR lastly.
GBAL wrote:HOW DO I PERFORM ANY UPDATES TO MY RBK753 SYSTEM
