51Alan
Mar 02, 2021Guide
RBK753 - won't find updated firmware
My RBK753 system is running firmware 3.2.16.22. According to the Netgear website the latest firmware version is 3.2.17.12, and it was released in late January. However, when I check for firmware up...
- Mar 02, 2021
It's expected that most Orbi systems will not automatically detect the new firmware release soon aftert it's announced and posted for manual download. For most customers it's okay and they don't need to update right away. Making these new releases available on the support website supports anyone who does need the latest fixes or who wants to upgrade as soon as possible.
It is normal for companies to gradually update their installed customers with new firmware or software versions. Mobile app vendors do the same each time they make a new app version available in the app store.
This gradual rollout policy is to reduce risk, e.g., if there is some unexpected issue with the new firmware they want to minimize the set of customers negatively impacted by the bug. By gradually rolling out new firmware releases and monitoring customer-reported issues, they can halt the rollout as soon as a small number of customers begin reporting issues. They can also accelerate the rollout as more customers use the new firmware but do not report problems. The gradual rollout period might be over several weeks or multiple months.
Rawcus
Mar 15, 2021Tutor
Very soon some guy will chime in saying you can do it automatically but the manual way is better. He'll then put a link to the manual method of updating the firmware.
This is a lie because the only way you can do it is the manual way.
You should contact netgear and ask why the adverstised method of using the app or the automatic process on the website doesn't work.
Mar 15, 2021Guru - Experienced User
I did, "V3.2.17.12 is available via manual download only from product support pages. We've purposely not put it on update server thus customers will not be pushed."
- vajimMar 15, 2021Master
FURRYe38 wrote:I did, "V3.2.17.12 is available via manual download only from product support pages. We've purposely not put it on update server thus customers will not be pushed."
This sure makes it sound like FURRYe38 works for Negear or he/she does a pretty job imitating a moderator. We've purposely not put it on update server thus customers will not be pushed." WOW!!
My favorite one is the "it works for me so it should work for you".
- RawcusMar 15, 2021TutorJust to be clear no version has been or is available via app update or automatic website update. I’m glad he spun the situation to act as if it’s this one version that won’t update.
- GBALMar 16, 2021AspirantSo then how do we fix the problem of my WiFi kicking out constantly?
