51Alan
Mar 02, 2021Guide
RBK753 - won't find updated firmware
My RBK753 system is running firmware 3.2.16.22. According to the Netgear website the latest firmware version is 3.2.17.12, and it was released in late January. However, when I check for firmware up...
- Mar 02, 2021
It's expected that most Orbi systems will not automatically detect the new firmware release soon aftert it's announced and posted for manual download. For most customers it's okay and they don't need to update right away. Making these new releases available on the support website supports anyone who does need the latest fixes or who wants to upgrade as soon as possible.
It is normal for companies to gradually update their installed customers with new firmware or software versions. Mobile app vendors do the same each time they make a new app version available in the app store.
This gradual rollout policy is to reduce risk, e.g., if there is some unexpected issue with the new firmware they want to minimize the set of customers negatively impacted by the bug. By gradually rolling out new firmware releases and monitoring customer-reported issues, they can halt the rollout as soon as a small number of customers begin reporting issues. They can also accelerate the rollout as more customers use the new firmware but do not report problems. The gradual rollout period might be over several weeks or multiple months.
bullm00n
Mar 17, 2021Virtuoso
Rawcus wrote:
I think you folks are mistaken in that when checking for firmware with an AX router it just says firmware check error. They all say that. It doesn’t work. Regardless the length of time after the release of new firmware.
I made a separate post simply asking the question if you have a router that doesn’t say that or you’ve been able to update the firmware post here. Please participate if this applies to you.
MY old RBR50 found the firmware updates and notified me about them. And My RBR850 did the same for one update when I first got it. This latest version of firmware, I was not notified, but found it through the forums and did a manual update. I have never seen "firmware check error" that I recall. I have never had an RBK753 set, but certainly the firmware updates work for similar ORBI devices for at least some users. If it is not working for you and indicating an error, there's likely some other cause - something blocking the check, a browser issue, etc.
This is what I see when I check now...
| Status: | ||||||||||
Model Name Device Name Current Firmware Version Status
Rawcus
Mar 18, 2021Tutor
Thank you for posting what looks like a paste of the website automatic process. Please attempt to do so with the Netgear phone app and let us know how it goes. Thanks in advance.
- FURRYe38Mar 18, 2021Guru - Experienced User
Same here:
- bullm00nMar 18, 2021Virtuoso
Rawcus wrote:
Thank you for posting what looks like a paste of the website automatic process. Please attempt to do so with the Netgear phone app and let us know how it goes. Thanks in advance.- RawcusMar 19, 2021TutorThis is when you try to update a rbr850 or rbs850? Sometimes referred to as the rbk852.
