alex81388's avatar
alex81388
RBK753 / AX4200 - 2.4ghz devices skipping satellite and connecting to main router
As the subject says, I have the following design, which is also linear in layout physically:   Router <=========> Satellite <===========> Cam   The Cam is connecting all the way to the router ove...
  • FURRYe38's avatar
    Dec 21, 2020
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
