Ed-K1
Jun 17, 2024Aspirant
RBK753-100NAR number of Extenders RBS750
I purchased a RBK753 with 2 satellite RBS750s last year. I would like to add additional satellites but can not find information on the number of satellites I can expand to. I ordered an additional R...
CrimpOn
Jun 17, 2024Guru - Experienced User
Ed-K1 wrote:
I ordered an additional RBS750 and it will not sync with the RBK753. I eventually reset all the equipment and it will only sync with the original satellites.
Please describe the process being used to add this 3rd Orbi satellite.
The typical pattern is to place the new satellite in the same room as the router (which makes conducting and observing the process much more convenient). After the satellite has successfully been added and appears correctly on the Attached Devices display, then relocate the satellite to the desired remote location.
If the normal "Add Orbi Satellite" method does not work, some users report success by connecting the new satellite to the router with a short Ethernet cable and letting them sync.
- Ed-K1Jun 17, 2024Aspirant
