Rustyrankin2213
Mar 03, 2021Guide
RBK753 and garden room
Recently purchased a orbi RBK753. Easy to setup and well impressed with WiFi and overall service. we are currently have a garden room built at the top of the garden around 20m from the main house. ...
Rustyrankin2213
Mar 04, 2021Guide
thanks for the reply, so connecting RBS750 or EAX80 to the nearest Satillite wirelessly? I only need wifi in there really but want a decent connection. would that work?
Mar 04, 2021Guru - Experienced User
IF you want best signal I would put a RBS or EX in the garage area, then run a CAT6 or 6A out to the remote room and either place a RBS or EX there connected to the other end of the LAN cable.
