Nnyan
Aug 21, 2020Tutor
RBK753 and Hayward Omnilogic Controller wifi
We finally have our new pool equiptment installed but I'm having trouble connecting the Hayward pool controller wifi to the Orbi network. The controller is 2.4Ghz only and I would like it to connect...
Aug 21, 2020Guru - Experienced User
Please post about this over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Nnyan wrote:We finally have our new pool equiptment installed but I'm having trouble connecting the Hayward pool controller wifi to the Orbi network. The controller is 2.4Ghz only and I would like it to connect to our guest wifi. But it just will not connect. It gets an IP address and I see it attached in the webui and phone app but the (simple) diagnostics on the Omnilogic is good until it tried to reach the gateway (192.169.1.1) and it fails and you can't continue. I don't know if it's trying to ping the gateway but that makes sense. Whatever it's trying to do it fails. If I connect it to the main wifi network (non-guest) it goes through fine.
Thank you for any help!
