Nnyan
Aug 20, 2020Tutor
RBK753 and Hayward Omnilogic Controller wifi
We finally have our new pool equiptment installed but I'm having trouble connecting the Hayward pool controller wifi to the Orbi network. The controller is 2.4Ghz only and I would like it to connect...
Aug 25, 2020Guru - Experienced User
If you connect both the controller the controllers app to both guest network, can the app connect to the controller?
I believe the Guest Networks uses a different IP address from .1.1, Also guest network is not supposed to have access to the LAN side, 1.1. so If you put something in Guest Network and try to access this device from the main LAN side, you won't be able to. How this works. I would presume that you should connect the controller to the main network if your the only one that has access.
Nnyan
Aug 30, 2020Tutor
It never gets that far b/c it fails the network setup phase (where the controller tries to reach the gateway). So its not found in the controller app and you can't bypass this phase. I understand that the guest wifi is on it's own network 192.168 network and can't talk to the non-guest network.
- FURRYe38Aug 30, 2020Guru - Experienced User
I would make contact with the MFr of this controller to see if there is any more information or help regarding there product.
