philipmarker
Apr 05, 2022Aspirant
RBK753 AX4200 - Router placement & daisy chain
Does this model support daisy chain ? When trying to find activate/deactivate box under admin log in (advanced wifi-setting), it does not pop up ?. Have problem with connection to one of the sate...
Apr 05, 2022Guru - Experienced User
It does support daisy chaining but it isn't user changeable. Its auto-negotiated within the orbi itself whether daisy chain or star topology will work better.
