djk1
Sep 12, 2020Aspirant
RBK753 can not connect to MyQ Chamberlain garage
So i just setup the 3 RBK753 via ethernet backhaul spread evenly throughout the house. I have gotten everything to 72 of the 73 devices in my house to connect but the MyQ Chamberlain garage opener. I...
- Sep 13, 2020
Can try changing the CTS value from 64 to 2347 and see if this helps any, Under Advanced Tab/Advanced Settings/Wireless Settings. If this fails,
Do you happen to have your older or prior 2.4Ghz router? If you do, you can do this, Connect this router behind the RBR. Can be in router or AP mode with this prior router. You might set or place this router near the garage device. Set up the wifi on this router for same SSID name and PW as used on the Orbi. Have the garage device connect to this prior router and get it configured. Once it's connected and setup, just turn OFF the prior router and the garage device should automatically connect to the orbi wifi signal. I would turn down the power output of the Orbi fron 100% to 25% while you do this with the prior router, then return it back to 100%. Under Advanced Tab/Advanced Settings/Wireless Settings
Sep 13, 2020Guru - Experienced User
Try disabling AX mode for 2.4Ghz on the RBR and see if it connects.
Contact the mfr of this device for additional information as well.
What FW version is currently loaded on the Orbi system?
djk1
Sep 13, 2020Aspirant
The firmware is V3.2.16.6_1.4.4 I think I already tried turning off the AX features in the 2.4ghz..
- FURRYe38Sep 13, 2020Guru - Experienced User
