wxd4000
Feb 13, 2022Aspirant
RBK753 DNS Setting greyed out
Hi, I have a Orbi RBK753 mesh wifi system, I recently noticed the DNS setting is greyed out, and I am no longer able to use my NAS as my DNS server. I have tried to reboot the router and disable the ...
wxd4000
Feb 21, 2022Aspirant
Thank you for your reply!
It is not in AP mode. Armor and parental control are disabled. Screen shot is attached. You can see the DNS setup is grey-out, the router MAC address is also not able to be changed
Feb 21, 2022Guru - Experienced User
have you tried a factory reset?
